Shift kit
I also have been wanting to install a shift kit in my 2000F-150( I also have the AODE4R70W)and after trading e-mails w/ another member(Jbrew)I have decided to install the Transgo shift kit(Summit racing p/n TRG-AODE shift kit)In the post I read,its fairly simple to install and really wakes up the transmission so it shifts and performs like it should,nice firm shifts and extends the life of the trans.I haven't read much about a performance valve body replacement,although at one time I was considering the Factory tech replacement,but the shift kit seems the way to go.I'm going to order mine from Summit simply because they include a video w/ the kit so you can see how everything is done,pretty cool.I tried the tuner to change and firm the shifts in my tranny,but it was not what I wanted, the shift kit is the way to go.If you still want to use the valve body,Troyer has an excellent one its a Factory tech,it will run you about $225.00. I hopes this helps,good luck w/ your trans.which ever way you go.
