if it is the same as mine then it is not a quick disconect type, if you look farther in it will have a bolt you can tighten, hopefully that is all it needs and it is not cracked, if it is cracked you might need a new radiator, hopefully it is just loose, good luck
 03 F-150 5.4 FX4 with HD supercharger swap at 10PSI, 6" fabtech with PA 3" body lift, 38"15.5" MT Baja claws, on 16" 10" extreem aloys, fabtech steering stabilizer, procomp traction bars, pro comp add a leaf, cranked torsion bars,4.88 gears, detroit locker in rear, ARB locker up front, troyer E-fans, X-cal 2 tuned by Sal, FTVB shift kit, on board air system, TONS OF CUSTOM MODS, AND ONE UNSTOPPABLE BEAST
