Somebody told me the other day that my 7700 4x4 had the same transmission that a lightning has. I couldn't believe that so, I was wondering what you guys think.
Read the sticky post above and check your door jamb sticker.
Steve
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Most likely you have the 4R70w tranny. 4 speed, 70(x100)ft/lb torque, and wide range. E4OD(Electronic 4speed Overdrive) was discontinued in '98 when the body style was revamped. The 4r70w was intended to replace the e4od, though it's not quite as strong.
All lightnings have the 4R100 tranny. It's possible your truck does also, check the trans code on the sticker and read the sticky.
97 was the new body style. I had a 4R70w in my 97 Reg Cab/Long bed 4.6
