Just the stator/clutch or the whole torque converter?
Old 05-28-2007, 10:10 AM
J420N's Avatar
My transmission is slipping, most likely due to the job I thought I needed carrying too much crap around. I have a new code about how my torque converter clutch has excessive slippage, which I can feel dramatically.
Would it be a better idea to replace the clutch in the stator or just replace the torque converter as a whole?
I'm sort of leaning towards the latter because I've never actually been inside a torque converter, don't even know if it's "supposed" to come apart. If I had the American cash dollars, I'd replace the tranny as a whole to a 5 speed.
Old 05-28-2007, 03:45 PM
rdeeno's Avatar
Unless you have over a hundred thousand dollars worth of equipment, you can't work on convertors. Problem is, if the convertor is taking a dump, it has already fill your trans with metal. It will look like glitter. If so, your trans needs to be gone thru.
Old 05-29-2007, 08:55 AM
dirtyd0g's Avatar
It probably has nothing to do with stator clutch. More likely the lockup clutch hhas peeled off.
Alan
Quick Reply: Just the stator/clutch or the whole torque converter?
