Transmission interlock switch
I took my 2004 screw 4X4 to the stealer the other day because my cruise control quit working. Anyway they told me it was the tranny interlock switch and they want $350.00 to fix it. Does anyone know where this switch is located and how hard it would be to replace? I'm no SAE mechanic but I do alot of my own wrenching. Any help would be greatly appreciated.
on
Originally Posted by BorderFord4X4
This is the switch that locks the shifter untill you press on the brake
That is the shift interlock solenoid. It is located on the steering column, under the dash.
It is in no way related to the speed control system except they each require valid brake light switch inputs to function properly.
If the shift interlock were malfunctioning, you'd be reporting problems getting the shift lever out of PARK.
Steve
Steve
Steve
