i did something bad when i replaced the filter on my C-6 today
something bad happened when i replaced the filter on my C-6 today
well i went and got a filter and pan gasket for the 85 F250 C-6 trans
i dropped the pan, no big deal cept i had to dremel the crossmemember bottom lip some to get a socket onto the middle rear pan bolt
after that the pan was down
then i started chucking what i thought were the filter bolts but i was actually in reality pulling the bigger valve body ones,
and the front end of the VB came down on me and then i realized that uh oh houston we have a problem its not just the filter coming down but its the VB too, i realized that i needed to be pulling the smaller bolts not the larger ones, too late though.
i am too used to gm transmissions in which this cant happen by accident on so i didnt even stop to see exactly what was going to come off with what bolts i was removing,
well anyways i went to push the vb and all back up to put the bolts back in and i couldnt get the vb up all the way, and well i made it go back up with the vb bolts torque
then i removed the smaller filter bolts, and put the new filter on and then the pan on and put in 4 quarts real quick and fired her up to try her out
well i had a new problem, i only had forward range!
uh oh....!
so i had to take it all back apart again and take the vb down and it looked like when i made the vb go back up it bent the linkage for the range selector and maybe also the kickdown lever too
not good,
i managed to bend the range selector one enough to get it back into the range selctor valve, but i never did get the kickdown link back into the opposite side of the valve, it now drives fine
what a pita
thee are three notches in the side of the valve on the kickdown link side of the valve
which one is for the link to go into ??
i odnt understand how youre supposed to get both links into both sides of the freaking valve when the valve is in the damn VB and youre on your back trying to put the stupid VB back up on the trans case and also at the same freaking time make the links go into both sides of the valve
impossible.
yet the damn thing sure fell off the link ends very easily when i pulled the stupid bolts,
so what the heck ?
is it ok to drive the truck with a non functioning kickdown ?
what a pain
thanks for anything
uh oh....!
not good,
what a pita
impossible.
so what the heck ?
what a pain
thanks for anything
ok thanks
i noticed even after the few new quarts of fluid in it the fluid is still pretty dark ill have ot drop it again and put a few more new ones in it
where can i get a pan drain kit for this steel pan at ?
we have auto zone oreilly and napa and a small farm supply and a hardware store here
nothing else
thanks
nothing else
thanks
ok thanks
is there a nut or something else that sticks up on the inside of the pan when it is installed ?
i mean its not flush inside the pan, or ?
if not then i could jut take a drain plug and get a nut for it and weld the nut in the pan
hopefully ill be able to do this tomorrow
right now ive got the pan down on the 97 F150 4x4
we have had to take it down three times now, it leaks everytime
going to get a ford dealer gasket tomorrow
tired of messing around with it
it is 14 bolt pan, what model tranny is it ?
says metric and reusable gasket, but it had an aftermarket cork one on it
the tranny shudders and doesnt act right, its 160k miles
probably too late for it
thanks
thanks
