safety Neutral Plug on Transmission Help needed
Plug on Transmission different size. Can I change Plug?
I have a 99 F150 with this a 4R70w automatic transmission, the transmission went out so I found the same automatic transmission out of a 97 F150 that I pulled myself. Now after getting it home I see that the Plug(where the larger red cap is on the tranny in the pic.) is 9 pin where my old tranny is 7 pin. How can I change the Plug?
Thanks in Advance for your help.
Chris
(this is not the tranny I have, I borrowed this pic for illustration purposes only)
Chris
Last edited by chrisharris; 05-14-2007 at 09:52 PM. Reason: Updating with new info
on
The big connector on the R (passenger) side of the trans is NOT the neutral start switch (NSS/MLPS/DTR). It's the main connector for the shift solenoids inside the trans. There's an article on TCCoA about how to convert between the 2 pinouts, and what else is involved, but the short version is: get a trans that matches your PCM.
