4r70w shifts good, wrong times???
Hey all...
just finished dropping in a new 4.6 longblock, radiator,heater and torque converter..
I must say with the locally rebiult converter , filter and valvoline mercronV..
convertr clutch seems smooth again..no shudder
here is what i can tell so far...all gears seem to shift ok, no slipping..
1 -2 seems fine
sometimes 3rd gear starts off with that binding sensation then clears out as you biuld speed with a steady foot.sometimes surging in and out of that binding sensation....at first i thought converter lock up to early but i am not entirely convinced just yet...
i do seem to be getting lockup in both 3rd and 4th
it really feels as though its not gettin the signal to downshift, or rather shifting to early..
i do seem to have to give too much throttle before a downshift
alot of symptoms going on here, not sure they are all related..i hope its all in control, vss, tps, electronics ion the valve body
i really dont think its internal, but i am unsure..first all electronic tranny
i am used to gm and ford detent cable
also had that heavy foot from a dead stop thing happen...goes nettral, then as soon as i let off the thing grabs and barks the tires...some crazy stuff
it seems like electric control to me, just dont know enough about these trannys to be sure..
any ideas of where to start
i have tried the brake switch test with the tcc, sometime i can feel it unlock, other times i wasnt sure..
most of the things i have read about here, are tcc solenoid, some kinda solenoids in the tranny, accumulator and spring(is this for 1-2)
tps
should i be checking any of these specifically...i want to try as hard as a i can before giving up and dropping it at the local tranny shop..
the long block has really hurt the wallet....
also have a hypertech programer from my buds 2000 v10 350
the plug is the same, but soemthing tells me i cant use it on the 98 4.6
well sorry for the jumbled mess,
but hope i can get to the bottom of this with out an overhaul...
thanks so much
Chris
1 -2 seems fine
tps
thanks so much
Chris
Best we can do is see some tel-tail signs and give some opinion.
1. There are several differnt converter stalls for 4r70 application. How do you know what you got?
2. The PCM controls shifting as it always did. If the trans has problems shifting, it's the trans.
3. The tuner may change shift tune on top of trans faults. You get confusing operation. Work it all out on stock tune first.
4. Lock up can be seen if there is a tach to watch as you drive. The rpm will change several hundred in unlock and seem to lock the needle to the engine instead of the throttle when in lockup.
Good luck.
Good luck.
hey Bluegrass, tarajerame,
thanks for the response
as far as the converter , they were suposed to rebiuld mine...hopefully this didnt require any stall changes,..it seems to be ok for the truck..
as far as the tuner, i really dont know what they are about, i thought i could use it to change it back to stock..
i guess the next question is, can the stock calibration go out of wack???
as far as lock up, i can here and feel the rpm change and load, so i am pretty scertain lock up is functioning properly..
and for the V-10 tuner, i havnt used it, but should have inquired rather if it could be used on the 4.6..
i was hoping to set it to stock if it was out of wack, but even if i had the proper tuner i dont think it works that way..
still stumped for now, though its hard to say,.. slowly , it seems the wacky shifts are becoming less and less, as if it is smoothing out a bit...
thanks to all
still investigating
Chris
thanks to all
still investigating
Chris
