drain torque converter (help)
Old 05-03-2007, 09:13 PM
Joe Styles's Avatar
I want to drain my transmission fluid (99 f150) and also found out there is about a gallon more in the torque converter.
What kind of tool or wrench do I need to pull the plug and drain that too.
Thank's Joe
Old 05-03-2007, 10:00 PM
dirtyd0g's Avatar
18mm ratchet to turn the crank and a 7/16 socket to remove the plug.
Alan
Old 05-04-2007, 12:08 PM
Faster150's Avatar
put the transmission in Neutral. get a big flat blade screw driver and pry the converter over till u get to the drain plug. unplug the injectors. and crank the motor till the drain plug is at the bottom.
Old 05-04-2007, 01:14 PM
bigdad8214's Avatar
But with the TQ empty how is it going to pump it's self back up?
Old 05-04-2007, 01:32 PM
dirtyd0g's Avatar
Put 5 quarts in the transmission. Start the engine and immediately add the other 7.
Alan
Quick Reply: drain torque converter (help)
