Is this a stock transmisison cooler ?
Old 04-10-2007, 04:42 PM
dennisfranz's Avatar
I got my truck from my father. It does not have a tow package without receiver, 7 blade adapter but does have the 130A alternator. It also appears to have this transmission cooler.
Is this a stock transmisison cooler and is it adequate for the occasional tow of a 2 horse aluminum bumper pull?
Old 04-10-2007, 05:21 PM
NHSP-06's Avatar
Before you go trying to tow anything, go get a hitch installed. Trying to tow a two-horse trailer just using your bumper as a "hitch" will result in you ripping off your bumper and the poor demise of those beautiful creatures you are towing. The most I would ever hook up to a bumper would maybe be a log splitter, but even then I would hate doing it. Hitches aren't very expensive (a couple hundred). Do the right thing and just invest in the hitch, it will save your horses lives and other vehicles on the road, not to mention yourself.
Old 04-10-2007, 06:10 PM
I agree.
Yea, I plan on getting a receiver for it instead of just a ball on the bumper. I can't stand that anyways. I have seen too many bumpers roll under or push into the tailgate from stopping too quickly with too heavy a load (if any).
I have a F250 7.3L for our living quartered 3 horse GN trailer but I got this truck for the 2 horse bumper pull for vets and around town. The larger is for travelling and camping.
Is this still a suitable tranny cooler and is this the cooler that Ford offers in its tow package?
Old 04-10-2007, 09:05 PM
Fire604's Avatar
Looks like the PS cooler, not a trans cooler.
Old 04-11-2007, 12:43 PM
bigtruck311's Avatar
i agree
Old 04-11-2007, 12:44 PM
NHSP-06's Avatar
PS cooler?
Old 04-11-2007, 02:58 PM
kingfish51's Avatar
That is a trannie cooler. The PS cooler is below the rubber piece, up against the cross-member.
PS Cooler
Trannie Cooler
It does look smaller though, probably due to not having the tow package.
Old 04-11-2007, 03:27 PM
jmt0645's Avatar
that is the factory trans cooler, the tow package would have been an upgrded version (bigger). that should be adequate for ~3500lbs, any more and I'd get a bigger cooler.
Old 04-12-2007, 09:25 PM
Thanks for the info !
Old 04-12-2007, 10:58 PM
off road dude's Avatar
if you get the receiver installed be sure to hook up the trailer level. ive seen too many people with it way up in the air causing everything to shift behind the axle and lift up on the rear end of the truck. and others with the trailer really low causing it to bottom out when pulling into some parking lots. and if it is level it will make for a smoother ride.
Old 04-13-2007, 12:45 AM
phil6608's Avatar
I just added this to my truck for a little extra tranny cooling.
http://www.chickenears.com/transcooler.htm
Phil
Old 04-21-2007, 03:46 PM
Intresting. I will have to keep that one in mind... THANKS!
Yep, it needs to be level also for proper wear on each axle. I have the single axle electric brakes as well and I was wondering if there is too much of an angle if one axle locks on hard braking? Probably on dirt/gravel roadways but maybe not on concrete. Then again I don't have to worry about that since it is gonna be level now that I know the hitch height with the new wheels.
Quick Reply: Is this a stock transmisison cooler ?
