auto tranny indicator problem
on
There is an adjustment wheel that you can turn to fix the problem. Remove the steering column cover. That is the gray plastic cover that has the black rubber that goes around the steering column. Not the black 2 piece on the column. It snaps out. You will see the star wheel if you look up under where the tranny indicator is. Place the Lever in Drive. The best way is to shift into first and pop up 2 places to drive. You need to weigh the shift lever down, tie an 8 lbs weight to the lever so it doesn't move. Now turn the star wheel and center it on the D. Done. Remove the weight and replace the cover.
JMC
JMC
