F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-19-2007, 06:22 PM
Vehicle: 1997 Ford F150
gear selector loose
I have a 1997 F150 that I got in May 1996. The problem I'm having is the gear selector on the column in the past week has gotten more play in it, or seems to be looser. It is tricky to put it into "P" and then when I go to start it back up, it takes moving the selector quite a bit to get the truck to start. Anyone have ideas on what needs to be done?
Old 03-19-2007, 06:27 PM
Vehicle: 2001 Ford F150
Send a message via AIM to zambonimaxx Send a message via Yahoo to zambonimaxx
Take the plastic piece off the dash that is above and around the steering wheel (feels like it will break off but it won't just pull bottom UP and OUT). Then you can see where the connector is after you move the black rubber boot up the selector shaft. You can then see if it simply the connector, or it may be the wire going from the selector to the transmission. If the wire is the problem I do not know how to fix it, but if its just the little bolt connector to the steering collum just tighten it a bit and grease it. See if that helps.
~Phil
01 4.6 V8, XLT, Supercab,Toolbox,4ft. CB antenna in Bumper/Midland CB radio, Edge Evolution II, Magnaflow DI/DO (12468), 2.25" exhaust piping Dumped, Fabtech 3.5" Spindle Lift, 2" Trailmaster AAL, Fabtech Performance 3 way adjustable Shocks (F), Tough Country 3 way adjustable shocks CS9000(R), 35/12.5/R16 Nitto Terra-Grappler, Recon Fire/Ice LED bar, Impulse Trailer Brake assist, Hi-Lift Jack Mounted on Truck Box, 5% Tint all Around, AF1 CAI, N-Fab Prerunner Light bar
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
