F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-17-2007, 04:09 AM
Vehicle: 1999 Ford F150
Exclamation Water in Transmission...
a couple weeks ago i flooded my truck in a deep hole. i drained all the fluids several times. the tranny fluid is still milky colored after 5 0r 6 changes. is there any way i can completely drain all the fluid out at once? each time i drain it from the tranny and transfer case only 5-7 qts drain out and i know it holds about 16 qts. How do i get all the fluid out of the torque converter and any other areas there might be fluid? or do i just keep changing it until it becomes clean? also are there tranny pans available with a drain plug?
1999 f-150 4.2 v6
Old 03-17-2007, 09:01 AM
Vehicle: 2009 Ford F150
Quote:
1999 f-150 4.2 v6
Pull the rubber plug at the bottom of the bell housing. Then turn the crankshaft with a breaker bar until you see the small bolt plug in the TC. Unscrew that and the TC will drain, albeit slowly.
Old 03-17-2007, 10:51 AM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Yup, there is a good 12-13 quarts in the T/C. Fortunatly your year has a drain. If you had an '01-'02+ you'd be screwed and need a flush.
Adrianspeeder
Old 03-17-2007, 12:53 PM
glc glc is offline
Vehicle: 2003 Ford F150
In this situation, you may want to go get a flush done.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
