Yes it is.
There isn't much to see. The fan/cooler can be seen thru the grill on the passenger side for a visual location reference.
The cooler is mounted on flat strap mounts cut and drilled from flat stock out of the hardware store, the fan on the front, the thermostat sensor tie wraped and insulated at the top inlet pipe to the radiator.
Fuse holder with a 10 amp inline fuse/holder off the battery + connector.
The fan draws about 5 amps. Not any more than say all the parking light.
The adjustable control is placed about center under the top cover so I can fine adjusted to where I wanted the temp controlled and now never touched.
There is no need for a switch unless a thermostat is not used.
Any problem and the fuse can be pulled or it blows.
Cut the return line metal in a straight section with tubing cutters, put a small flare on each pipe and double clamp the hoses so it can't blow off.
Route the hoses so they never have a chance to fold over and restrict the flow.
Re-check the clamps in about 2 weeks, for tighness. The hoses relaxes.
If you still need a photo, I will take one but it will just be through the grill same as discribed.
The rest of it is just a matter of looking over the places, as discribed.
