F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-12-2007, 02:36 PM
GEM removal?
I'm having problems with my 4x4 trying to engage without any imput from me through the shift lever. I believe the problem may be with the GEM. I'm able to get the lower part of the dash off but after that I'm lost. There seems to be another plastic case enclosing the fuse panel and GEM. Does anyone know how to access this. I have read on this forum that the fuse panel has to drop down before you can get to the GEM. Any help would be appreciated.
Old 03-12-2007, 08:11 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
The pre 97's have to come through the engine side of the firewall. Donno 'bout the newer trucks.
Old 03-12-2007, 11:17 PM
Vehicle: 2002 F150 super crew
Reading your inital post leads me to feel you have no idea how the system works and the service info you need to work with it.
Basicly and assuming you have a switch on the dash, the switch is the first signal the GEM recieves to begin the requested action as well as the switch signalling relays and transfer case motor and vacuum solenoids.
The relays and tranfer case motor return signals to the Gem that set's the mode lamp and operates the vacuum controller on the axle.
Barring water leaking onto the GEM from a bad windshild seal and causing your problem, you have quite a bit of troubleshooting to do.
Replacing the GEM need carefull consideration as it is a programmable module and needs to have the programming in the replacement as it was in the original.
Good luck.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
