F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-10-2007, 12:42 PM
Vehicle: 2002 FORD F-150
02 F150 Tranny lines leaking
Do not know much about this but was told by my dealership during my last repair visit that there are 2 tranny lines in front of my truck one on both sides of the truck that are leaking near the front of the truck underneath the motor. The service manager stated that they leak because of the crimps that Ford uses and it is a weak design, he also said that the only real fix to have both lines replaced unless I wanted to try using rubber hose and hose clamp that alot of guys with super-duties use where you cut out the leaking parts and bypass them with rubber hose and hose clamps, but that the hose/clamp idea may not work with the F-150 because the tranny lines are too small for the the hose clamp to get a good grip and will eventually leak themselves.
I don't feel like spending money to have the tranny lines replaced if they are a weak design to begin with and will leak again so I would rather do something more permanent since a revised version of the tranny lines is not available from Ford..are there any aftermarket lines available that don't use the weak crimp or has anyone tried the hose/clamp idea with success?
Thanks,
T
Vehicle is 02 F150 4x4 5.4
Old 03-13-2007, 02:59 PM
Vehicle: 1994 Ford F-150
Send a message via AIM to 1994f150XLT Send a message via MSN to 1994f150XLT
The hose and clamp idea is the next best thing to getting aftermarket or revised hoses. Use a quality Neoprene Hose, not Rubber, as rubber will dry rot and swell. Use fuel injection hose clamps, Not the regular old worm gear clamps. Fairly easy fix, really.
-Jimi
Old 03-13-2007, 06:34 PM
Vehicle: 2001 ford 250
the rubber line will work fine. just make sure it say transmission cooler line right on the hose. 3/8 i believe. youll want at least 2 good hose clamps on each end. when you cut the bad part of the metal line take a file to smooth over so the rubber slides easily over it.
Old 03-17-2007, 09:52 PM
Vehicle: 2004 Ford F150
Thanks,
T
Vehicle is 02 F150 4x4 5.4[/quote]
Replaced mine a month ago with the hose/clamp. Seems to be working fine.
Cpt.
Old 03-18-2007, 02:01 PM
the rubber hose and clamps work fine. in not even sure if you can buy factory replacements even from the dealer. as long as its tranny line and good clamps youll be fine. i had that setup for a year on my old dakota woth no leaks. if it makes you feel better just flare the end before you put the hose on.
Old 03-18-2007, 02:19 PM
Vehicle: 1998 Ford Expedition
Try Inlinetube.com A lot of hot rodders and restorers use them. They make stainless steel and regular steel replacement lines for brakes, fuel & transmissions. They will make any line, but if they haven't made one for your specific vehicle yet, they will need the old ones to get the masurements and bends factory correct. Their quality is excellent.
Old 03-30-2007, 12:03 AM
Thanks all, forgot about this thread due to busy life, etc adn the truck has not been a priority-but thanks again for the info, going to go ahead and try the hose idea!!!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
