gears
HI!... You most likely have 3.55 gear ratio. That is the most common gear ratio in the F-150's. But with yours being a limited edition BOSS. You might have got 3.73 gear ratio. Like stated before, check the tag on the rearend diff cover. There will be two. One will be the reaend identification tag. The other is just a tag telling you to use synthetic oil in the diff. If you are missing the identification tag or can't read it, simply jack the rear of the truck with jack stands. Take some chalk and draw a line on the driveshaft. Then draw a line on the sidewall of one of your rear tires. Sin the rear tire 360 degrees and count how many times the drive shaft turns.
- 3 turns = 3.08
- 3.25 turns = 3.27
- 3.50 turns = 3.55
- 3.75 turns = 3.73
- 4 turns = 4.10
And so on.
- 3 turns = 3.08
- 3.25 turns = 3.27
- 3.50 turns = 3.55
- 3.75 turns = 3.73
- 4 turns = 4.10
And so on.
