Towing
Towing
How can you tell if your truck is set up for towing, as in tranny, tranny cooler, right gears, right rear end???...my buddy is looking to buy a 05 FX4 and it does not have a tow package...is there a way to tell if you can just hook up and hitch and the truck already has a tranny cooler and the right gears and such , or if you would need to install them after the fact...do they all come ready for towing or are parts needed on top of the hitch???
you should be able to see the tranny cooler in front of the radiator. small radiator looking thing. if not, uhaul has some that i have never had any problems with. you could get it all there. (hitch and tranny cooler)
As far as gears, mine has 3.73 and i dont have any problems at all. I tow an 18' ski boat and some jet skis, as well as some stuff and random trailers for work.
you need to check the GVW rating on the Id sticker on the door. it will tell you exactly what you can pull with the truck. any truck is set up to pull a trailer of some sort . the GVW tells you how big of a trailer. if the truck is factory equipped with the trailer tow package it will be reflected in the GVW rating.
That sticker only tells you the GVWR of that vehicle that sticker is mounted on. It also tells you the GAWR for the front and rear axles, tire size, tire pressure, vin number, other codes, etc.
On that sticker near the bottom it will say AXLE what two digits is right below that?
It'll tow.
If it's an F150 with a V8, it'll tow just fine as is...you'll just need a hitch (obviously) and trailer wiring. An extra tranny cooler, though it wouldn't hurt, wouldn't be necessary for snowmobiles or small boats. I doubt that a brake controller would be either, because I'm sure that those smaller trailers don't have brakes.
My company sells and installs towing packages...we put towing packages on cars that tow jet skis and small trailers, so an F150 will be fine, trust me.
Hitch, wiring, and get-r-done.
I'd suggest a hitch from Curt Manufacturing. Quality stuff with the best finish out there, IMO.
Good luck.
Good luck.
Depending on what kind of package you got...it either came with it or not. You can always upgrade but I know it was a requirement for mine to have a towing package. If you upgrade be sure to get a brake controller (again depending on the towing you do). A two horse trailer and changing area (Adams) needs a brake controller because it has electronic brakes. Anyway take a look at your package included in the dealer sticker (otherwise check out your manual).
~Phil
~Phil
