Throttle Response / Acceleration Hesitation Delay = 2006 F-150 Lariat 5.4L 4x4
Old 02-10-2007, 08:27 PM
bkshl's Avatar
Could someone please let me know why I’m having an Acceleration Hesitation at 30 – 40 mph? It feels like the onboard computer has a built in 2-second delay in between the gears. I have 7K miles on my 06 F-150.
Last week I had Ford re-program my trucks computer to the most current revision (also called Flash update). They found 06-Sept Rev that they thought would fix my problem. Well, 200 miles later, no change and I still have this Acceleration Hesitation Delay.
Does anyone have a fix or solution to this problem?
I was thinking about installing these two items:
A.> JET Performance Chip Power Control Module http://www.autoanything.com/performa...0A2067797.aspx
B.> Airaid Cold Air Intake System
Does anyone have these installed?
Is JET Performance a good product?
Thanks for any help/Info!
Old 02-10-2007, 09:48 PM
gilsnuxs's Avatar
EDGE
No had a similiar problem with a hesitation especially when merging onto the highway. My edge fixed that problem right up.
Old 02-10-2007, 10:29 PM
jmt0645's Avatar
what ever you do STAY AWAY fom the Jet chip, you'd be better off with the EDGE
Old 02-12-2007, 10:14 AM
raptorman01's Avatar
I have that same problem merging onto highway, aggrivating as hell. Mine is an 06 5.4 as well.
Old 02-12-2007, 10:18 AM
Either an Edge or a Troyer tuned Xcal2. I had a bad hesitation that was dangerous, the dealer reflashed and it solved that problem, but I had a real dead spot as it accelerated through 2nd. The Edge solved all my problems!
Quick Reply: Throttle Response / Acceleration Hesitation Delay = 2006 F-150 Lariat 5.4L 4x4
