4x4 Problem
4x4 Problem
I went through a medium sized mud hole on a buddies farm the other day. He's got a 1500 Chevy with 35's on a 6" lift, He made it through in 2 wheel drive easy, Well im running 33's on a 3" lift and I wasnt as lucky in 2 wheel drive. I put it in 4 wheel drive(manual shift in the floor) and I felt it start to 'crawl' like they do in 4 low but my front tires would not spin, its got automatic hubs.
Whats the problem???
I actually have the exact same problem got stuck in a damn ditch the other day and had to rock my truck out. It almost seems like the front axel isnt engaging maybe the vacuum to the axel or maybe the actuator itself, try putting the truck on juck stands and see if the 4x4 front drive shaft coming out the transfer case is spinning might help getting to the problem Good luck
