"'95 f-150, Engage clutch and RPM's jump but only when driving
Old 01-31-2007, 01:12 AM
Landrecker's Avatar
I just got a 1995 F-150 5L V8 with manual trans. When I am driving it will go fine but when I step on the clutch and let off the gas to shift gears the engine revs up to 2200-2500rpm and stays there for 10+ seconds before it starts to come down. When I let off the clutch and the engine re-engages the rpms drop back down. This only happens when I am driving. If I am stopped and rev up engine then let off the gas it drops right back down. I also noticed today that after I let the truck idle when I warm it up the engine throbs and cause the tach and battery guage to bounce. not sure if that is related problem or a whole different trouble.
Please help with any suggestion or thoughts.
Old 01-31-2007, 02:23 AM
Steve83's Avatar
Sounds like the IAC is sticking. Read this.
It's not for your symptom, but it's still related. It could also cause the tach/voltage surging at idle.
Clean & tighten your battery terminals.
Quick Reply: "'95 f-150, Engage clutch and RPM's jump but only when driving
