can you drain the converter in 4r70w
Next week Im going to drain the pan and replace the filter in the transmission of my 2002 lariat with the 4r70w. Does the bell housing have an access hole for draining the converter and does the converter have a drain plug to drain it? This is my first experience with the 4r70w. Also if anyone has any tips for my project this weekend Im all ears. Thanks
I have the same tranny and I'm pretty sure when i changed mine there was a plug in the Torque Convertor. Just pull off the rubber access plug and rotate the convertor until you find it.
Edit: If you don't go to Ford for the replacement filter, double check the gasket shape in the parking lot at autozone. It took me 3 trips before those idiots got it right luckily i didn't drain it first. Remember the fluid type is Mercon V, and your gasket on the truck should be a bitchin resealable rubber kind, so don't put on that cork crap, or over tighten it. I'm also pretty sure that it takes 13 or 14 quarts so double check the owner's manual first, or give 12 quarts start it and check the level on the dipstick and add accordingly.
Originally Posted by elcamino12sec
Just to confirm, if there is a plug on the bottom of the inspection plate I should be able to drain the converter,
