1994 f250 4x4 transmission prob
Check the fluid level in your CLUTCH MASTER CYLINDER. Don't forget to remove the rubber cup under the top of your master cylinder lid, it just lays under there. If it's low, your slave cylinder is probably leaking. Don't be too alarmed if it's low you can probably just add a little fluid from time to time and run it a long time that way.
