upgrade flywheel?
Old 01-01-2007, 12:24 PM
built54's Avatar
upgrade flywheel?
Since im going to install a new converter, what would be a good choice for an upgraded flywheel? Im sure the teeth on mine are kinda worn because sometimes the starter grinds hard when trying to start it. Anyone change theirs? what kind would be good to get, mine should be an 8 bolt.
Old 01-01-2007, 01:19 PM
built54's Avatar
So neal, i noticed you have one. is this the one you have? pa26478-8 Is it heavier or lighter than stock?
http://www.mustangunlimited.com/item...s&CatKey=74-01 thats the one im thinking
Old 01-01-2007, 02:15 PM
Neal's Avatar
HI!... I got mine through PERFORMANCE AUTOMATIC. It's SFI approved. Looks like that one you posted might be it. I have a 4R70-W if that matters.
Old 01-01-2007, 02:20 PM
built54's Avatar
I have the e40d, but the same flywheel. Do you have the website you got it from? how much more or less does it weight from stock? 164 teeth right?
Old 01-01-2007, 02:25 PM
Neal's Avatar
Talking
HI!... I'm not sure , but I bet it weights a tiny bit more due to it's SPI approved. It would be slightly beefier than the stock flexplate.
Old 01-01-2007, 02:29 PM
built54's Avatar
so would that be in any way power restrictive? http://www.performanceautomatic.com/flexplates.htm there it is, but it says it bolts to a c4...
Quick Reply: upgrade flywheel?
