4x4 light stuck on?
4x4 light stuck on?
Last week my '97 f-150 MT 4x4 starting making this horrible grinding noise in the front end. Simultaneously, the 4x4 light would come come on. After reading on a few forums I found others had experienced this problem and attributed it to a faulty transfer case mode switch. I replaced it with a new one from the local dealer and so far the grinding noise has not returned but now the 4x4 light on the dash won't go out. The truck is seeming going from two to four wheel drive just fine but the indicator light says its always in 4wd mode.
Any ideas? I tried disconneting the battery for about 20 minutes to see if resetting the computer would help but the light is still on. Thanks.
on
A manual lever shift? If so disconnect the new switch and see if the light goes out. The switch actually grounds the circuits to signal the GEM to turn on the indicator lights in the instrument cluster. If unplugging the switch turns out the light then the switch is defective. If it stays on you may have a short to ground or a defective GEM.
JMC
JMC
JMC
JMC
Thanks.
