Question about clutch
I have a 2003 f-150 with a 4.2 and a 5 speed. When im letting the clutch out from first gear it feels normal and engages right away but when im shifting from 2nd-3rd or 3rd to 4th i feel like the clutch doesnt really engage until the pedal is more than half way out, it feels sloppy. Maybe its the fact that im driving with a 33 inch tire but it just doesnt feel right. Any opinions what it might be?
on
Has anyone ever messed around with the pedals, or anything under the dash? Have you checked the fluid quality & level? How many miles on the clutch? Yes, the larger tires WILL have an effect.
If you have a tach, find the pedal position in 1st where the clutch really grabs. Then try to get to the same spot in a higher gear, hold the pedal there, & see how hard you can tap the gas pedal withOUT the RPM surging (clutch slipping).
on
Not likely. It sounds like it's just the effect of the large tires, but try to check it the way I described. The clutch may be worn out because of the tires combined with your driving style. Try to spend as LITTLE time as possible transitioning between FULLY released (pedal down) & FULLY engaged (pedal up) to minimize wear/heat on the clutch, pressure plate, & flywheel. That means you'll need to learn to feather your throttle during the shift so the truck doesn't lurch or grind - those are bad, too.
I'm familiar enough with mine that I can usually speedshift it - not using the clutch at all, but just slipping it out of one gear & into another. You have to learn the RPMs for each speed, though, & feel the synchronizers thru the shifter.
Alright ill give what you said a try when i get back to school on tuesday. Is there a particular minimum rpm youre thinking that is an acceptable point at which the clutch should slip at a higher gear?
I only plan on doing this once as i dont really feel like burning out my clutch and having to replace it as im on a student budget haha.
on
