Accumulator Body?
Accumulator Body?
Ok, here goes. I have been having the same problem with the hard shifting in my 97 f150 5.4 4X4 with the E4OD, as 98mkiv has had with his Expedition. I am going to try to get some codes for you guys, but Casey1 talked about it might be the Accumulator body. I have never opened an auto trans before, and am trying to get an exploded view of one, so I have an idea what to look for. I cant afford to take it to the shop, with christmas just over. I havefound that if you stop and turn off the ignition, and start itback up, it stops for a while, "until the next time it is driven". I need some help here guys. Thanks.
Have cades now what?
I only got 3 codes, Now where can I go to get an idea as to what is actually wrong, broke, or out of adjustment?
P0503 Vehicle Speed Sensor Intermittent (current code)
Stored in history
P1867 Transmission Transfer Case Contact Plate General Circuit Failure
B1352 Ignition Key-In Circuit Failure
Stored in history
