Differential Oil
I end up going through deep water before any significant amount of milage so I end up changing more often than others.
I pull the cover to make sure any metal shavings come out with a good cleaning. Reseal with RTV and your good. Don't forget if you are limited slip to add Ford's bottle of friction modifier.
Adrianspeeder
Adrianspeeder
Diff
Originally Posted by UberDude
Ford-design axles are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected, service is required or the axle assembly has been submerged in water.
I can be guilty of overkill on preventive maintenance.
Originally Posted by dixieF150scab
Yeah. The manual says it's lubed for life unless you go into the water or, I believe, tow a good deal. My Haynes manual, however, mentions something about checking it at 30,000 mile intervals, and changing it at 60,000 mi. if necessary. I supposed I need to just drop this concern, huh?
do whatever helps ya sleep better at night.
i hate to make it sound like that manuals the holy bible for your truck. its a guide and if you feel better having your diff. oil replaced then do it.
heck if you take it to your dealership, and the mechanics honest and knows what he's doing, he'd probably ask you why you want it changed if it hasn't seen any hard service or been submerged.
but most likely he'd smile and say, " yup, you got 'er in here just in time, she was about to explode".
BUT like i said. do what make YOU feel better. i've come here with the same questions and gotten all kinds of answers but in the end i did what i thought was right. and if what i thought was right turns out to be what these wonderful people told me then cool.
