Swapping from M5OD-R2 to a ZF5
I have a 94 F150 4X4 300-6 with the Mazda 5 spd. I would like to swap out the Mazda tranny in place of the heavy duty ZF5 model, since the ZF5 has the "granny" 1st gear. Would the ZF5 bolt up to my t-case?? Are the two trannys the same length? Any major mods that I would have to do to get this to work?
Thanks alot guys!!
Thanks alot guys!!
Originally Posted by adrianspeeder
You would need a ZF5 from a 351 4x4 truck. The 460/7.3 IDI/7.3L PSD all have different bell patterns, and a 4x2 tranny won't bolt to your xfer case.
Adrianspeeder
Adrianspeeder
on
Originally Posted by Steve83
Remember that you have more choices than just those 2; there's also the NP 435 & BW T-18/19. There's a transmission thread on FSB somewhere that lists virtually every trans used in F-series up to ~'97.
The list of trannys is also a sticky at the top of this page also.
