wher to get 4wd solenoid
Originally Posted by korte500
99f150
are these 4wd vacuum solenoids a dealer only item?
I think you mean "Acuater"
If your talking inside the trans - Summit has those as well.
If not , this will get you close -
http://store.summitracing.com/egnsea...115+4294770978
nah, the solenoid dealios up on the firewall, that has two vacuum lines.
Your must be talking about the EPC solenoid - only other thing I can think of.
Let me know , I'll see if I can locate- Part # be nice , but not needed. I need the proper name lol. What motor do you have? need more info
thanks jbrew, i wasnt referring to the trans, just looking for some quick advice. im referring to the vacuum solenoids on the firewall that everyone on here talks about. Im getting vaccuum, and power to the 4wd solenoid, but nothing coming out, when in 4wd. tried tapping, using air blowgun, hahah
oh yeah. 5.4 1999 112,000 miles. ive owned it since 52,000 and have only had to put brakes, and tires on her. im going to do the plugs, and coils, and wire/s? and maybe the fuel pump, for peace of mind. do you know where i can get those cops?
I can't find them solenoids on AllData.com - wonder why , I know there on there , I was just cleanining my acuater last week when I changed out the diff. and seen the vac hoses. I'm still going to look for mine to see what you mean - next time I have the hood up.
The blow gun didn't work aayy, lol
Kevins the owner of Global Automotive - If you order
your COP's from there, write him an email or call - specifi the
plugs you want or you'll get the wrong ones - that's if you get the kit.
http://cgi.ebay.com/ebaymotors/NEW-F...temZ8069960486
-Joe
got one
went to the dealer, and got an ("valve" part # 6l3z-ph465-b) the guy said that it was an ignition part # and had a hard time finding it.
the news is thats why my 4wd wanst working wooohooo
i tested the old one with vacuum on it, while power plugged in, and nada.
$45 later, im back in 4wd. bring on the snow wooohooo
Yeah bring it on!! If it's going to this cold in Michigan , let it be white!!
LOL
How hard was it to replace? I had mine in the shop to figure out why it wouldn't engage and they said it was a solenoid which only the dealers have.
I haven't actually looked at it yet, but where about on the firewall are they located. Mine won't engage so I know its the one that engages.
They're on the passenger side of the firewall, near the hood hinge. They have two vacuum lines and an electrical connector each.
It may not be the engage solenoid. If either one sticks, it can cause the problem. You'll need to either troubleshoot it further, or replace them both to be safe. Otherwise you've got a 50/50 shot.
-Joe
-Joe
