Tranny identification
on
"RPO codes" are a GM thing, like "positraction" - not Ford.
http://www.fordf150.net/howto/decode.php
Ya, after I read the thing that Steve pt up I saw that stickie and realized how much of a douschbag I looked like haha. Maybe we should add the link that Steve put up, it lists the axle options as well. Thanks for the recommendation though! Do you guys the bellhousing from the E4OD on a 300 would match up to a 302? Thanks again!
Just curious Steve, is your last name Ford? I wasn't sure if since the 300 was an I-6 if it would classify as a smallblock or not. Ive got an older Cartier (mustang) 5.0 I was thinkn about swapping for the 300. This is music to my ears to hear i dont HAVE to pulld the trans all out as well. Thanks alot guys!
From the tranny sticky at the top of the page...
Model: 4R75E
Type: Four speed, rear wheel drive, and 75(x10)lbs of torque
Years: 04-06 F150/ Mark LT
Engines: 5.4L
Display: PRN(D)21 w/ overdrive lockout switch
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: B ('04-'05), Q ('06), F ('06 Mark LT)
Adrianspeeder
Model: 4R75E
Engines: 5.4L
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Adrianspeeder
