Aftermarket Pans
Aftermarket Pans
I am looking for an aftermarket pan for my '02 5.4l Screw with 4R70W (trans code U on the door tag). We are going to be pulling a 5000-5300lb travel trailer (dry weight) and want to do what we can do get a few more years out of our truck (70k mi). I want to get a larger capacity trans pan that has a sending unit bung already in it. Does anyone know of one available for less than $200? I want to measure the temps at the pan. Does anyone make a kit? I looked on Summit/Jegs but did not see a pan for less than $200 that had the bung already in it. Those mag-hytec's are fancy but yeesh....high dollar. I plan to install an additional trans cooler as well.
Thanks guys,
-L
Thanks guys,
-L
B&M Pan
I ordered my B&M pan at car-stuff.com.I just called to get the info you will need to know. 178.00 is the cost and the code #343869,with free shipping. I also installed the factory teck plate while the pan was off. About $85.00. I have engine and trans oil temp gauges,a must have. eGauges.com was my choice. I hope this helped a little. I almost forgot,the part # is 40291 for the B&M pan. Bill
