5.4 tranny
Old 11-23-2006, 05:41 PM
jcea412's Avatar
5.4 tranny
my tranny is slippin and i need to swap it out but i dont know what model to buy and cant find the info anywhere any help appreciated. also will a 4.6 tranny bolt up to a 5.4?
Old 11-23-2006, 07:38 PM
F151's Avatar
Did you try a flush and fill? I hear some came through Ford without synthetic fluid, causing this problem. My '00 F150 started hard shifting into overdrive. Had a machine flush done, new Mercon5 fluid, and it's good as new. May be worth a try, unless it slips so bad the bands got heated. Then your screwed.
Old 11-23-2006, 07:57 PM
projectSHO89's Avatar
The transmission is NOT specific to the engine.
Read your TRAN code on the door label and then look up your tranny model in the sticky at the top of this forum.
Old 11-23-2006, 09:44 PM
TheBandit's Avatar
yeah what he said.Sticky is good !
Quick Reply: 5.4 tranny
