f150 Manual Swap (same ol' question)
okay guys... been doing tons of research and here's my dilema... got an '02 5.4 n/a bone stock (reg cab, flare side, 2wd), went to put in a transgo shift kit (not cool!!! dont try it! research 1st. tons of posts from old ford engineers on how bad that is for a 4r70w!!! increase line pressure w/ a chip!!!) wouldnt work. at first, was stuck in 2nd all the time. after going back to a stock valve body i bought off ebay, it will ONLY go into reverse. worked for a test drive through all 4 up and down then tried to test passing gear downshift, thud... driving back to the crib backwards!!!! still sitting... boo hoo. perfect fluid level, filled w/ mercon V, so no, not fluid, no leaks...
now... i am sooo sick of this trans, i was pondering swaping a 5 speed manual out of a GT mustang. i know i can get that gear box to bolt up, i can fab up a trans mount, and get a shaft made. the brakes are one thing in question, the position of the shift linkage is another. i know the vaccum booster wont work so hot on the manual. ive done these swaps on older carburated vehicles, but something this new.... i was hoping to find someone that has done it b4, hopefully w/ mostly bone yard parts, and some fabbing. best thing i could find was a guy who put the 5.4 in a stang gt (02 or 03 i think). god i want that trans in my Boss5.4... it would live up to its name a little more... ati procharger is next, so getting the brakes to work right, and the check eng light to stay off is a must for me... think i can do it? any feedback? please help!!! stay tuned...
on
The distance from the edge of the bellhousing, where it bolts to the engine, to the center of the shifter is about 18 inches on the 00+ M5OD. The Stock T-56 is about 26. The shift lever on the T-56 can be relocated closer to the bell housing but I am not sure by how much so you will have to check. Check out the available gear ratios too. I think the best you can do is 2.99 1st on the T-56. The M5OD has a 3.9 1st. You could just get an M5OD but you will end up breaking it. A ZF is taller than an M5OD so it might hit in the transmission tunnel. Never easy....
JMC
JMC
on
I am still breaking the M5OD's. This is the third one that I have installed. I am saving up for a ZF S6-650. The T-56 is readily available from aftermarket suppliers. Call these guys. http://www.ddperformance.com/ I don't understand your question about the vacuum for the brakes.
JMC
JMC
A guy did a T56 swap on fordtruck world. He had lots of posts about it under "transmissions" in the forums, but I couldn't find them very easily. I remember it being a 6 speed from a mustang cobra and it costing a fortune. Also, the tranny length came very close to the seat, but did work. Here's a link to his photo album. Good Luck if you decied to do it.
http://fordtruckworld.tenmagazines.c...49-album-37793
Great posts guys! that really helps. JMC, i was just wondering if you did anything at all to the brake system besides maybe a little pedal re-working. i was looking at my buddies GT mustang, and its brake booster is powered by the PS pump vs a vaccum booster on our 150's. i am going to look for a t56 locally. see if i can find one. my truck isnt a hauler, or a mudder, more of a street truck than anything. i do plan on throwing on a Scharger, so i need some extra strength. i was trying to keep it somewhat cheap, so a custom bellhousing and a gearbox for 2 grand is a little much. but since my truck is immobile, i can justify it a little more
okay, so it should be just a simple pedal swap on the interior, and making sure i have clearance for the shifter... i can always fab up a shifter w/ proper bends to make it comfortable, no biggy. the t56 is pricey, and the m5 is junk... anyone ever try it w/ the tr3650 out of the late model stang? i wonder what kind of beating it can withstand... my buddy pounds on the gear box in his '02 gt, which is why i was even considering.
okay, so it looks like i am going with the tr3650 out of an 02 or newer 4.6 stang. should bolt up, flywheel should be easy and clutch too. ford rates that gearbox at 360 ft/lbs tqu, and its in the new gt which makes 300hp/320ftlbs.... w/ 3v 4.6 stock... my 2v 5.4 doesnt push that, added wieght is a stress factor of course, but what i dont understand is how you can throw an Scharger at that 4.6 and the tranny still holds (under normal street use). does ford under-rate these torque specs? another question ive been researching is the speedo... looks like the sensor for it is located w/ the abs, on the wheels somewhere, and the stang is the same. i am used to a cable and a gear in the trans. is this true? is it as simple as configuring the ecm? or am i way off here?
