Quote:
Originally Posted by Viper5035
axle code is 26 is there a formula to find out what the rpm's should be at at a certian speed
YES...formulas....have fun
DGR = Diff Gear Ratio
TGR = Trans Gear Ratio (1st=2.71, 2nd=1.54, 3rd=1.00, OD=0.71)
D = Tire Diameter in inches
DGR = RPM*D/336.09/MPH/TGR (not exact but can tell 3.55, 3.73, 4.10, etc)
Viper has 265 tires so D=30.5", MPH=75, RPM=2100
DGR = 2100*30.5/336.09/75/.71 = 3.58 so Viper has 3.55 diff gears
or
RPM = 336.09*MPH*DGR*TGR/D
RPM = 336.09*75*3.55*0.71/30.5 = 2083 RPM
BUT 26 axel code says 3.73 so I must have guessed wrong on the tire dia. Viper, are the tires 31.8" or 32" tall? If I got the tire size right then the RPM should have been 2200 at 75MPH. The best way is to use 3rd, get accurate RPM and tire dia.
