F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-23-2006, 08:51 PM
flat tow with M50D
Can I flat tow (4-down; engine off; in neutral) a M50D at 55mph for a few hours without damage? I'm not a tranny guy but it seems to me that the rear end will still be turning the main shaft so will it get any lubrication - or does that matter?
I read somewhere that Ford said it was OK for the M50D but I can't find the lilnk. Any opinions? (otherwise I guess I crawl under and disconnect the drive shaft)
Old 10-25-2006, 04:21 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
The output shaft relies on splash from the gears on the intermediat shaft for lubrication. When in neutral the intermediat shaft stops turning. No turning equals no lube.
JMC
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 10-26-2006, 08:46 PM
Thanks so much - that is unfortunately what I figured out as well - she'd roll to hot. (Drat) Thanks again
TR
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
