Quote:
Originally Posted by JMC
The factory pressure plate has adjustment. It has to be set during installation.
JMC
Oh contrare....There are no 'adjustments' to make. I'm a mechanical engineer for the company that makes 75% of all Ford truck clutches. I don't design them anymore, but I can tell you it's not air in the system. He's right about the 'mushy' feeling he'd have and the pedal engagement would be at the floor - not at the top of the travel.
The symptoms noted would most likely indicate;
1). bent disc / driven plate (from factory or from installation caused by not supporting the trans adequately during instal)
2). Disc is 'hanging up' on the input shaft - did you lube it? The disc needs to be able to slide / float easily on the shaft, so it can back-away from the flywheel when it is released so the input shaft stops spinning.
3). Defective parts (were these 'New' parts? From where? Many companies use Chinese product now, although they calim they don't which identical the original, but functions poorly - we have found our own parts copied, right down to our own die marks from our presses!!) The disc cushion (between the friction material) has a specific dimension it must maintain, like 1.8mm. If this is too high, you get your problem.
Although the pressure plate may 'lift' enough to drive, the disc is still dragging on the flywheel which does not allow the input shaft of the trans to fully stop - that's why it's difficult to shift into 1st. If the disc is bent, same effect.
If the parts were "remanufactured" - throw them out. You can tell by looking at the face of the pressure plate. It should have lathe cut (circular) marks/grooves...not cross-hatch blanchard grind marks.
I could right a book - but this should help you. In any event, you need to take it back out. Sorry. Make sure you use a transmission jack, if you didn't the first time to ensure you don't distort the disc going in.
PS - Some Heavy truck clutches are the only ones which are manually adjusted - although this is going away now too.
