F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-23-2006, 03:05 PM
tranny fluid question
I have a 2001 f150 2wd 4.2 v6 with the 4R70W transmission that takes the mercon V fluid. Well what happened is i added a half a quart of regular mercon fluid to the tranny on accidnet without realizing i grabbed the wrong quart of fluid. Is this really a bad thing and need to get the tranny fluid changed? or can i just get a quart of additives and add the recommended amount ???
Old 10-23-2006, 03:37 PM
Vehicle: 2002 Ford F150
A half quart isn't going to make any difference at all. Forget it.
Old 10-23-2006, 03:41 PM
ok well along the same lines a day later after i added this half a quart, my tranny didnt seem to wanna kick down after putting the pedal to the floor after already going about 40-50 mph. This is what was making me think that i really f--ked something up. Any ideas of why this won't kick down at all??
Old 10-23-2006, 03:45 PM
Vehicle: 2000 Ford F-150
I wouldn't think so, but when are you due for a tranny fluid change anyways? I'd say if soon, change and forget it, but if you're still a ways away, still shouldn't matter really so forget it too. Now I hear the Mercon V is to be used instead of the older dextron 3/ mercon as a replacement, so you're bound to have at least of quart of old flowing around with the V anyways. I changed the fluid in the transfer case which is supposed to be Mercon only with Mercon V, and no problems so.
Old 10-23-2006, 03:53 PM
well it does have 83,000 miles and the fluid doesnt look bad at all. Is it easy to do your own tranny fluid change??
Old 10-23-2006, 04:02 PM
Vehicle: 2005 Ford F150
Pretty messy job if you do not have proper drain facilities, assuming you do not have a drain plug in the transmission pan. You have to drop the pan with fluid in it.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Old 10-23-2006, 04:06 PM
eh no big deal about dropping the pan. When changing fluid does the TC need drained as well?
Old 10-23-2006, 08:03 PM
yeah you need to drain the tc too.its not hard just a bit of a pain.i use a crowbar to spin the tc after you remove the grommet in the bellhousing until the drain plug is at the bottom.you might wanna spin the tc and make sure you have a drain plug.some trucks don't have em and i think it was on 01's
Old 03-09-2007, 08:28 PM
the other day i was looking at changing out my EGR valve for emissions testing here in a month or so and noticed the one of my connectors at my throttle body (throttle position sensor im assuming) was damn near disconnected. I plugged it back in and its been running like a champ for a week now.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
