F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-22-2006, 07:54 PM
1999 F-150 Which Tranny To upgrade 2wd 2 4wd conversion
Hello All,
I have a 99 f-150 with the 4.2 and a 5sp tranny. It has been converted to straight axle and now it is time to do the tranny. I am wondering which transmission I should go to and which transfer case. I am hoping to find a bolt up already together combo. I appreciate the help.
b
Old 10-22-2006, 09:41 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Howdy and welcome!
Your 4.2L shares the bell housing pattern with the 302 and 300, so you could just use a M5OD-R2/Borg Warner 1356 combo from an 88+ F-150/Bronco or another '97+ 4.2L (not 4.6L) F-150.
One hangup from your current setup is shown in this thread by JMC. He'll chime in with what is goin on.
M5OD differences
I'd really like to see your solid axle swap. What did you use?
Adrianspeeder
Old 10-22-2006, 10:47 PM
Thanks Adrianspeeder. I will take some pics and put up a link to them. It looks pretty good, but allot of custom work.
Old 10-23-2006, 01:56 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
I am assuming that you are going from a 4x2 to a 4x4? Go to http://car-part.com/ and look up the tranny and T-case for your model year. Unfortunatly the 4x2 5 speed will not in any way shape or form bolt up to the t-case. Been there done that got the t-shirt. You may have to extend the speed sensor wire as the sensor is in the extension housing on the t-case.
JMC
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 10-24-2006, 04:47 PM
Here is a pic of the truck and front suspension. I am getting gears into it, that is the reason for the jack under the axle.
Old 10-24-2006, 05:20 PM
Cool! Dana 60 up front? Looks like a 9" in the back?
Old 10-24-2006, 05:41 PM
Quote:
The front is a Dana 44, although I am keeping my eye open for a Dana 60. You got the rear right though, it is a 9" with 5.14 gears.
Old 10-25-2006, 01:18 PM
NICE! What did the axles come from?
Adrianspeeder
Old 10-25-2006, 03:04 PM
Adrianspeeder
Late 70's model 4x4.
Old 10-25-2006, 03:20 PM
JMC JMC is offline
After seeing pictures of your truck, nice truck BTW, I expect a stock clutch will not hold up for long. I would seriously look into a ZF from a superduty along with the t-case. EDIT: A 95-96 Superduty used a ZF S5-47 transmission. In 96 it was bolted to the gasoline engines so it should bolt up to the V6. It has a wide ratio gearset 1st 5.72 2nd 2.94 3rd 1.61 4th 1.0 5th 0.76 Reverse 5.24.
JMC
Old 10-25-2006, 07:41 PM
Quote:
JMC
Thanks. You know your stuff JMC. I will look into it the superduty trans case. Hopefully I can find one.......
Old 10-25-2006, 10:07 PM
Just a point, the 88-97 Superdutys (what the F-450 is now) arn't the same as the '99 plus Superdutys (F-2/3/4/550s) are.
You need a 88-97 F-2/350 ZF-5 tranny from behind a 300 or 351 to bolt to your 4.2L.
The beefier S5-47 version was used in 95, 96, and 97. Don't rule it out, as I think the S5-42 found from 88-94 would also be fine behind "only" a V6. Keep in mind this tranny (albet different ratios and bell pattern) was even used behind the 7.3L.
As a warning the 4x4 ZF in the small bell housing patterns arn't given away due to their popularity in half ton truck swaps.
Adrianspeeder
Old 12-13-2006, 10:06 PM
I have an update and issue. I decided to go with an M5OD and BorgWerner.... Fit in nicely without any issues untill...... I went with the crossmember that came with my 2wd because asside from being a side mount versus top and bottom, it was the same basic shape. Anyhow, because of my massive lift, the from driveshaft is not going to clear the crossmember. So, is my only option to box the member and cut away intill it will clear????? Any thoughts are appreciated. Thanks.
Old 12-14-2006, 10:18 AM
JMC JMC is offline
What cross member is it not going to clear?
JMC
Old 12-14-2006, 06:35 PM
JMC
Sorry bout that. It is the front.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
