trans gauge question???????
Can any one tell me how to put trans gauge on 4R75E tranny from '04 f150?
would like and trying not to cut/modify cooler lines, and keep stock sensor.
Also do the gauges HAVE to be graounded to engine orcan they be grounded anywhere(as long as good ground)
THANX
THANX
manifold
forget last update just found this
do you think it will work?http://www.jegs.com/webapp/wcs/store...tegoryId=10333
Originally Posted by jegs
A Temperature manifold is required on most late model cars to allow continued use of stock temperature sensor for input to car's computer control unit.
Fits 3/8'' O.D. Tubing.
And yes flaring tubing isnt easy with basic hand tools, actually almost impossible with basic hand tools.
-Patrick
I put mine in front of the radiator. Bought a fitting kit for a trans cooler, a tee, 2 hose barbs and a couple feet of tranny line. No cutting and a cresent wrench puts it back stock in moments. Check out my gallery. Hopefully I will have the picks of my finished cluster and LED conversion on my gauges up soon.
WV
WV
