F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-21-2006, 10:37 PM
Vehicle: 2000 Ford F-150
4r70w tranny actin funny
Today, passing someone going slow enough to kick it in first, no prob, hit second and wind it down and just when I know it should be shifting to third, it's like it went in neutral, then finally shifted after I adjusted pedal giving it a little shot of gas. After that nothing! Anyone have this?
Old 08-22-2006, 01:16 AM
And on the way home just now, everything is fine. Could this be electrical? How bout springs or the o/d band? Not sure where to go with this as it happened once, but don't want any repeats if I can help it. It's a 2000 f-150 4x4, 5.4 4r70w. Any suggestions of components and what makes it shift? Thanks in advance fellas.
Old 08-23-2006, 03:31 PM
shift problem
I had the same problem that started small and got worse ... (read my thread which is down the page) and finally took it in to have it looked at. They found a broken spring and piston that was locking up. My problem started small and got worse... and after they fixed the 2-3 shift , now my OD starts to slip when it gets hot.
Old 08-24-2006, 10:45 AM
I'm going to have to remember it for when it's time to fix, but the truck has run absolutely fine since, weird huh! I drove around 500 km's the day after and was flawless, even other problems seemed fine, again weird. I'm going to have to have my tranny guy fix if it's a little too in depth but thanks for the 4-1-1.
Old 08-25-2006, 01:15 PM
Added to that I checked my shop manuals and it looks easy enough to fix, I was going to do a fluid change shortly anyhow so I'll look into it.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
