I took 1-2 accumulator apart tonight, everything looked pretty OK...no broken springs etc. Bore had a slight bit of roughness but very little. The accumulator was old style (aluminum w/ o-rings) . I have the updated piston assembly and springs ordered from Ford Dealership and they will be here tomorrow. I was able to remove it without removing VB, I am hoping I can re-install it with leaving VB in place...is that possible? Other than polish the bore slightly with scotchbrite is there any tricks? The inner (upwards) bore was not as easy but I did get a little polishing done, other than no scoring/roughness it that all I need?
