F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-17-2006, 12:41 AM
F150 Tranny Problems
95 f150 4x4 5.8L automatic E4OD
i changed the filter and added new fluid. i put 5 quarts in it, and it was showing low when the truck was hot and at an idle. i added another half quart and drove it some more and it showed way too full.
i took some fluid out and now when the truck is off and cool, and outside temp is above 50 the tranny fluid shows half way up the cross hatch area. when i start it and run it through the gears and check it while running in park, it barley has enough fluid to cover the loop at the bottom of the dip-stick.
the owners manual says to drive it 20 miles, or check it wile engine temp is cold when outside temp is above 50. checking it cold didn't do any good. and i'm worried about driving it and taking a chance of really messing it up.
what should i do??
Old 08-17-2006, 12:49 AM
Vehicle: 2005 Ford F150
I always check and fill with the vehicle at operating temperature...that will give you an accurate indication of the fluid level. A pan for an E40OD is pretty big so I'm betting you are just a little shy on the fluid...
Old 08-17-2006, 01:38 AM
Quote:
when i drive it a short distance it shows good, but if i drive it through town then back home it is showing way high. my engine temp shows about 175-180when i'm checking it after 2-3 of constant driving in hot weather
Old 08-17-2006, 10:21 PM
Never check it with the engine off, this is not accurate.
Just how high is way high? If it si slightly above the cross hatch like a half inch or so I wouldn't sweat it. Your goal is to get it in the cross hatch at full operating temp in park with the vehicle running. I wouldn't trust just a hot idle...Hope this helps sort it out....
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
