F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-15-2006, 03:21 AM
Vehicle: 2002 Ford F150
4x4 Front Wheels
I got a fabtech 6 inch lift put on about 3 months ago and sing then I have gone off-roading twice. Each time I get majorly stuck in small pits of mud. It seems as though my four wheel drive isn't working correctly since I only seem to have my rear wheels spinnign in the mud. My front drive shafts spins but the front tires dont. I have no idea whether this has to do with my transfer case or just a lack of power.
Old 08-15-2006, 07:58 AM
Vehicle: 1997 Ford F150 4x4
Check the vaccuum lines that run down to the front axle, make sure they are connected and that they are not leaking anywhere...had the same problem with my work truck a while back, turned out the vaccuum lines had come disconnected from the front diff and 4WD was not actually engaging, although the lights indicated it was...
'02 F250 Lariat CrewCab, 4x4, 7.3L PSD
My Gallery
Old 08-15-2006, 08:04 AM
Vehicle: 1999 Ford F-150 SCAB
Yep, I'll second that the front differential isn't being engaged. That's why you're not spinning the front wheels. You're basically offroading with a two wheeel drive truck. Check all the vacuum lines to the front diff and I'll bet you'll find one that's either leaking, disconnected or broken. You have more than enough power to spin the front wheels.--DIY
Modifications
Fiberglass Ram-Air Hood, Tubular Stainless Steel Grill, Back Country Nerf Bars, Roll 'n Lock Retractable Tonneau Cover, Rhino Liner, Flowmaster Force II Exhaust ,K&N Drop-In Fliter, Silencer Removed, Air Box Modded, Auxiliary Back-Up Lights, Halo Headlights
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
