F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-10-2006, 08:17 AM
Vehicle: 1997 Ford F150
Send a message via Yahoo to 97on37s
Question correcting speedo
Does anyone know where I can get a one of the those plastic speedo gears that goes in the tranny to correct the speedo?
1997 F-150 5.4 supercharged 4x4 Off Road
6" RCD Lift and a 3" body lift
37/13.50 Procomp Xterran
488 gears Front and Rear
Southern Born Southern bread when I die I'll be a Southern man dead. 100% REDNECK
Old 08-10-2006, 08:59 AM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Ford parts counter. My dealer even has a chart sayin what gear for what tires.
Adrianspeeder
Old 08-10-2006, 04:10 PM
ok thanks but do they carry the gear? I already know I need a 39 tooth.
Old 08-13-2006, 12:40 PM
Does anyone know how to get the correct speedo gear? I need I know the one 2 get. The dealer said I need to make sure before they order it. please help.
Old 08-13-2006, 02:45 PM
I'm confused.
Old 08-14-2006, 12:04 PM
The stock gear is usually a 19 or 20 tooth gear. I had a 20 tooth with 3.55's and 29" tires. When I got 31" tires, I put in a 19 tooth gear. This corrected the speedo/odo. (my speedo was 'slower' then actual, so I needed to speed up the VSS)
With 4.88 gears and 37" tires, you are about the same as I would be with 4.10 gears.... I'd guess you will need either a 21 or 22 tooth gear.
What's the number of teeth on the gear you have in there now? How far off is your speedo now? My guess is that you are seeing higher mph and running more miles then actual, correct?
Mitch
97 F150 XLT 4x4 Super Cab 5.4. 200,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
