Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 07-22-2006, 08:02 PM
Garage is empty, add now
Vehicle: 1989 ford F150
Clutch Hydraulic Line and flywheel ?'s
I have done a search and understand thatu need to push the white collar in but mine was severly abuse and cut in two so it just came right out. Now what do i do to remove the line. the reason of removind it was to replace the flywheel ring gear. How hard is it to remove the ring gear and replace or should i replace the whole flywheel? 89 150 4x4
Old 07-25-2006, 12:36 PM
JMC JMC is offline
2000 Ford F-150
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Cut up a hose clamp till it is the same length as the collar. Slide it into place where the plastic one goes and then push on it using 2 screwdriver tips.
JMC
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD w/ Hurst short throw, Warn XD9000i, OBX Long Tubes /w Cats, Troyer E-fans, P-1SC Procharger @15psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
