Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 07-22-2006, 01:20 PM
Garage is empty, add now
Changed Fluid And Help!
Hey Guys,
I just changing my trans fluid and installing a Mag-hytec pan. Everything was great, installed the pan and new filter, filled with new trans fluid. When I went to dump the container holding the old pan, filter and fluid there was a yellow plastic plunger looking think laying in the bottom of the old pan. It looks like kind of a Pawn chess piece. There is a o-ring on the large diameter. The tip is maybe 1/4" and about an 1 1/4" long and the big diameter is maybe 7/8" diameter and about 1/2" long. Any idea what this is and where is goes. I could take a digital picture if that would help.
Thanks for your help!
Brian
Old 07-22-2006, 01:46 PM
Vehicle: 1997 ford f-150
That is a plug that they put in the trans dipstick opening at the factory. They do this because the dipstick is installed after the trans is installed and this keeps fluid from spilling before the tube goes in. When they put the tube in, they just push that piece into the pan. It is there until you drop the pan to do the first service.
Vehicle: 1997 Ford F150
I was caught by the same thing. You can throw that plug away. It was put in the fill tube at the factory to keep trash out of the trans before it was installed in a vehicle.
Finding that plug indicates this was the first time the pan was off since the trans was installed when your truck was built.
97 F150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Live Wires & Coil Packs, Underdrive Pulleys, Troyer Performance Dual 16" Electric Fan Kit, 3.55 LS, EGR Bug Deflector, Retrax Bed Cover, BedRug, XL Full Length Running Boards,EGR Fender Flares, Air Aid Kit, Gibson Single Out Cat Back, Superchips, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks,Expedition Center Console
Old 07-22-2006, 02:32 PM
Thanks!
Great explaination guys, you made my weekend!
You guys are the best!
Brian
Old 07-22-2006, 03:56 PM
Vehicle: 11 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Howdy and welcome!
I think it's a new record around here too. This hasn't been asked in two weeks...
I'll let it slide if you post some pics of the truck
Adrianspeeder
Old 07-24-2006, 01:21 PM
Vehicle: 2007 Ford F150
Talking
Brian
Tell me you did not throw it away!
It the hig-a-majig poshotty valve flux capacitor whicha-ma-callit plug!Without it,your tranny will blow up!
I wish I could see peoples face when they see that plug in the pan for the first time!
2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
The anticipation of death is worse then death itself!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
