Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 07-16-2006, 05:18 PM
Garage is empty, add now
Vehicle: 1997 ford F150
clutch is out, Do you see a problem? PICTURES!
Well the clutch is out.. Before I ask any questions...what do you think of the condition by looking at the pictures. It's not as bad as I thought. Also in the first picture the cylinder is different looking...any problem? or did ford just add a boot.
What do you think of the pics? did I pull it for no reason? Clutch slipped at lower RPM's Truck has 69k 97 4.2 2wd
Click the image to open in full size.
Old 07-16-2006, 05:19 PM
Old 07-16-2006, 05:24 PM
Vehicle: 1994 Ford F-150 4x4
Strange. You say it slipped only at LOW rpms?
The PP definately has some hot-spots.
That disk looks pretty good on the PP side. The flywheel side looks like it had some problems. Did you have a rear main leak or anything?
Do you have any photos of the flywheel?
Old 07-16-2006, 06:22 PM
I did not notice the rear main leaking, but will check. here is the flywheel pics.
Old 07-19-2006, 11:50 AM
JMC JMC is offline
2000 Ford F-150
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
The new slave cylinder that you show in the pic is an improved version. It is better than the one you pulled out as it is less prone to leak. I noticed that the pressure plate is a Luk. They are one of the good brands so if it slips then it will continue to slip. So if your clutch was slipping then it needs to be replaced and the flywheel needs to be refaced. You could get away with scuffing the flywheel but I would at the very least replace the rest. And don't forget a new pilot bearing.
JMC
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD w/ Hurst short throw, Warn XD9000i, OBX Long Tubes /w Cats, Troyer E-fans, P-1SC Procharger @15psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
