Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 06-25-2006, 10:17 AM
Garage is empty, add now
Vehicle: 2002 ford f150
HELP! found a part in Trans pan
pulled pan to change filter and fluid, found a part that looks like a miniature toilet plunger (plumbers friend) . It has an O-ring around the fat part. It's white plastic. Truck has 105K miles. 4.6 v8 2WD automatic.
Truck has been running OK. Several months ago, on the highway going up a hill, when the RPM got down low (1500-2000) it would start to shudder. I could kick it a little gas, RPM would kick back up and it'd stop. Hasn't done that it months.
What is this part? where did it come from? This is the first time the pan has been off to my knowledge. If it's important, why is the truck running, OK?
Old 06-25-2006, 10:28 AM
Vehicle: 11 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
It is a plug that gets pushed in on the assembly line when the dipstick is inserted. Good indicator that the pan was never off.
Welcome to the forums!
Adrianspeeder
Old 06-25-2006, 10:29 AM
Vehicle: 1997 Ford F150
Smile What you found is the dust plug.
Is this the first time that you have changed the fluid or have removed the pan?
If it is, this is an excerpt from my Haynes manual;
'Upon initial service most transmissions will have a plastic plug lying in the bottom of the pan. This plug was used to keep contamination out of the transmission while on the assembly line. Discard the factory installed dust plug.'
Hope that helps
Old 06-25-2006, 10:31 AM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
If I had a nickel for every time someone asked about these, I'd have a whole lot of nickels
Alan
Old 06-25-2006, 10:50 AM
Adrianspeeder
THANKS !!!!!
Old 06-25-2006, 10:52 AM
Hope that helps
THANKS ! to timberwolf, Adrian Speeder, and DirtyDog for your quick replies. I've got to take the fam 3K miles and i was panicking big time!. it'd be nice if ford would emboss this thing with DISCARD on it !
Old 06-25-2006, 08:27 PM
Vehicle: 2007 Ford F150
Talking
OH NO! Did you throw it away? That was the pisshotty-hig-a-ma-jig reverse osmosis fluid plug!
I wish I could see the expression on peoples face when they see that plug in the pan!
2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
The anticipation of death is worse then death itself!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
