06-19-2006, 01:17 PM
2000 Ford F-150
Vehicle: 2000 Ford F150
5r55 Tranny fluid change (Mountaineer)
What's the story w/ the trannies in these vehicles?
I told my Dad I would help him change the tranny fluid in his Mountaineer (2003, 4.6L, AWD) - at the time I assumed it would be a very similiar process as the F150's 4R70. I start looking into it, and apparently it has a completely sealed system - i.e. - no dipstick. How is one suppose to change the fluid and filter in these trannies if you don't know how much fluid to put back in, much less a place to put the fluid in?
Has anyone ever changed fluid and filter in one of these before?
06-19-2006, 01:51 PM
Garage is empty, add now
Vehicle: 11 FULLsize ole' Ford rigs
Nope, tried to do it with the neighbor's 03 explorer. Sucks how they screw us into forcing the dealer doing work.
Adrianspeeder
06-19-2006, 06:36 PM
Best bet is to have fluid exchange done at the dealer or shop of your choice. Just make sure they refill the system with Mercon V. Prices can really vary so shop smart. Had a 14 qt. exchange performed on a Ranger for $69 at Big Ten Tires a few years ago with a coupon from the Sunday Paper. Ford dealer wants $150 for the same service. Most shops use a T-Tech machine to exchange the fluid.
06-19-2006, 07:12 PM
Vehicle: 2004 Ford F150
Quote:
Adrianspeeder
Think of it as Ford forcing the DIY'er into getting the service done by someone who knows what they're doing.
There's a specific drain and fill procedure for the 5R55, and unless you've got something that's capable of shooting fluid into the transmission via the check plug or fill plug (depending on what year it is), and (optionally) a scan tool that can read trans fluid temperature, this service is best left to someone in the know.
!@#$ the language filter.
06-19-2006, 09:49 PM
Or they could make it so the DIY'r can do it. Whas-a-matter with a drain plug and a dipstick anymore?
Adrianspeeder
06-19-2006, 10:31 PM
Prolly 'cause they don't want any flak about the DIY'er doing his own trans service and goofing it up somehow. Wrong fluid, not enough fluid, too much fluid, no fluid, and then toting it to the dealer on a flatbed, screaming that the vehicle is a piece of junk.
06-19-2006, 10:33 PM
2000 Ford F-150
I went surfing over at: Serious Explorations (Explorer/Mountaineer forum site) and found a couple of methods that combined will work. Looks like I'll have to drop the pan to change the filter and clean the magnet, put the new filter in and reinstall the pan. Then go to the tranny cooler, take the lines off, have a small hose in new ATF and a hose in an old bucket to collect the old ATF, and then have someone run the vehicle until new fluid starts coming out. Then reattach the lines to the trany cooler and go to the oil level check plug on the tranny, and by using a threaded adapter and a hand/vacuum pump, pump a couple of quarts of new ATF in until it is overfull, then let the excess drain out the oil level check plug.
What a PIA
06-24-2006, 09:27 AM
These aren't so bad. You can do two different things. You can remove the vent fromt he back of the transmission and dump fluid in from there or you can push the fluid in through the drain plug. When you remove the pan you will see the drain plug is two parts. The outer part goes up to where fluid level should be. The inner part is to let the excess fluid out and push new fluid in. To fill these after service push about 4 quarts into them and quickly reinstall the drain plug. The start the vehicle and breifly run it through the gears. Then remove the inner plug to let excess come out. If none comes out add more until it comes out. I suggest filling the transmission cold and checking the level warm. One thing is for sure there is no clean way to service these.
Alan
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company |
